1998 suzuki ltf500 4x4 wont start
hey there guys just found this cool site and im having a problem with my suzuki quad its a 98 ltf500f 4x4 the guy i got it from hadnt ran it for some time the tank was dirty so i im pretty sure the carb was so i cleaned tank completly got a carb kit and clean it up and installed that now it wont start it will run as long as i hold the starter button in( it will rev up) but when i leave off the starter button it stalls i have checked and rechecked the carb dont think it is that.last thing i did to night was take the air cleaner side tube off and the slide dosent move up and down but it is free and when i run the throttle it moves if that helps any thanks again: Tony
ya there is a fuel bump on every four wheeler or snow mobile have you tried by taking the fuel line off the carb and cranking it and see if the fuel come out of the line have you tried using starting fluid or putting gas in a spray bottle and spray it in the carb well cranking it to see if it will fire then that will narrow it down what it could be
You are incorrect, atvkiller, very few ATVs have a fuel pump, most run gravity feed from the tank to the carb, some use engine vacuum, like the Suzukis, to pull gas to the carb, but have no pump. Only ATVs with tanks under the seat or lower than the carb require a pump. On your Suzuki, is there a "prime" and "run" setting on the petcock, with no "OFF" position? In run, it uses engine vac. to pull fuel, and will not flow without the engine running, prime is to fill the carb without having to crank the engine over, you can leave it in prime and pull the hose to check for flow to the carb. If the tank was dirty, I would put a fuel filter in line to the carb, pull the carb and make sure it is clean, the pilot jet is very tiny, if that is even partly plugged, it may not run, or run very poorly. When you cleaned the tank, did you remove and clean out the petcock? if that has dirt or rust in it, it may be restrictig flow to carb, causing running problems
Well, according to my Clymer repair manual, on page 290, they do use a fuel pump. But, I suppose you know more about it than they do.....
