1985 suzuki lt230ge shaftdrive wont idle
hi i got a suzuki lt230ge and ive rebuilt the carbs twice and it still hasnt idled tigtened all bolts on upper engine seeif thatd help it didnt.
checked intake gasket fine air filter fine blew all holes out on carb with carb cleaner only thing left is to boil.
is there anything else it could be, before i take it all apart again
please help thanks
aprreciate it
mike
please help thanks
aprreciate it
mike
May be nothing to do with your problem but I have just had an Eiger that wouldn't rev slowly, it got so the clutch was engaged all the time with both the stop and cable slack. I cleaned out the carb and noticed that the throttle disc was closing off the carb completely, so where was it getting air/fuel from? Only possibility the choke on all the time. The lever travel did seem a bit short but the cable was working. Anyway, got a new cable and the inner is 1/2" longer, fitted it and the fault has gone, but how can a cable get shorter, all I can think of is the outer got longer due to rust, the bike had been used in salt water.
house1
08-09-2015 10:49 PM
CRamshaw777
07-18-2015 05:46 PM
07-15-2015 02:07 AM
ranvette
07-12-2015 06:34 AM
