lt230s timing chain replacement
take the top cover off, take the chain tensioner out, take out the camshaft, then turn the chain until you find the master link, take it apart, hook the new chain to the old, then either turn the motor over until you can disconnect the old chain, or just let the chain fall down into the bottom some(so that it falls from the bottom sprocket) and rotate it until the link where the old chain and the new chain connect comes around to th4e top...then you can hook the ends of the new chain together...and wa-la, presto-chango...
if thats to confusing, i can try to explain it differently
hmmmm, ok.....i plan on taking the side cover off to inspect the guides, would i still need to remove the cam if i did it that way? i have a manual but doesnt go into much detail wtih the timing chain......local cycle shop said that i would have to remove the cam and flywheel... do all chains have a masterlink?
you dont have to remove the flywheel, or even open the bottom if you hook the two chains together. but i can see why you want to open it...
yes every chain should have a master link in it.
buy another mag cover gasket and a tube of high temp rtv, so when its time to reseal you'll be set. all you gotta do is work the old timing chain around the fly wheel and pull it off. when you put the new one on, just run a piece of string or mono fishing line down through the jug and work the new one on. it sucks not removing the flywheel but it can be done.
Hankey Pankey
26
10-18-2020 03:50 PM
