need help carbartor
need help carbartor
ok so i'm rebuilding/rescuing a suzuki LT 230 shaft drive. it hasn't run in like 5 years.
last night i pulled the carb off dissassembled it and soaked everything in carb cleaner for about an hour and a half. used a brush to do some fine cleaning and then put it back on.
i was able to get the egine to start and idle if i used a sock to control the air flow.
with out the sock it won't start. i talked to the small engine shop and the guy told me that the carbartor is prolly still dirty. or that one of the jets is still cloged.
i've read about cleaning the jets out with a wire, i want to know how many differant places there are in the carb that i need to run a wire into.
i really only found 2 jets that i could remove,
there was a third one but i couldn't get it out i turned it my hand (because no screwdrive would fit into it) but it didn't come out it just turned and turned.
the jet you are talking about not coming out is most likely where the float needle sits in right? that one you gotta pull out doesnt screw in. i had the same problem till i yanked on it one goot time and it came out. but that really shouldnt have anything to do with your air flow cuase all that jet does is monitor the gas that is currently in the bowl.
You may want to boil the carb like others have talked about on here.
I haven’t tried that myself but others have and said it works great. I can tell you I've tried soaking the jets off my 230 in carb cleaner and it didn’t help much if at all with the old gummed-up gas…………
http://sites.google.com/site/suzukil...-s/carb-tuning
Go to the vault site will tell you everything about the carb................
Carb Tuning - Suzuki LT230S Vault
If you are talking about you put a sock over the carb it started and ran fine where the air comes in, and you are running it without an air filter, thats probably your problem. You need an air filter. An Air filter restricts alot of air and without an air filter, you will get dirt in your engine. You are probably also running really lean with all that air flow and your probably gonna ruin your engine if you run it like that.
