LT230 chain guides?
as for why the chain is resting on the swinger. either the swinger bearings and axle bearings are shot or the chain is not adusted correctly or its stretched to the max. check the bearings for play and do yourself a favor, get an O-ring chain. if there is any slop or play in the bearings in the swinger change them fast, or you risk throwing the chain through the mag cover. pm me if you have any questions, i am a qualified online mechanic for the lt230s 85-88.
chain problems...
first of all since the transmission sprocket is so far in front of the swingarm the tension varies when the swingarm is at full bottom and full top.
most common failure i can find is the bearings on the swingarm, see if it has play and moves back and forth, or sit on it and lean left and right ask someone to see if it flexes on the bolt that holds it.
the bearings are tiny needles and tend to become destroyed with use. I replaced mine with plastic sleeves instead.
Now if the bearings there look ok on the extreme rear of the swingarm there should be 2 12mm bolts pointing downwards.
Loosen the bolts and get a large monkey wrench. the rear axle has like a 4 inch circle that the axle goes through, you will see the the axle is not centered in this, rolling the carrier in the center(look for small holes for a pin wrench, or look for marks from a pipe wrench) changes how the off center circles line up and moves the rear axle forwards and back changing the tension.
If moving the axle to the farthest it goes back does not add enough tension either the chain is stretched too far and must be replaced or the bearings in the swingarm are done. Or a combination of both.
Proper chain tension is very hard to do on this bike and is critical in not exploding your magneto cover.
Send me a message if you are interested in buying a case saver.
Thanks for all the good advise! Surprising enough, the swing arm bearings are not shot. Even with allot of motorcycle swing arms, the needle bearings always seem to be worn out. My concern was of the missing chain guide buffer, I have since found that it is a round sleeve that I am missing and will order one. Since you have to remove the swing arm to replace it, I will service or replace the bearings as well as chain and sprockets.
Thanks again,
Jeff
Thanks again,
Jeff
Thanks again,
Jeff
Thanks again,
Jeff
cannot find a case saver at all
lt230s - BikeBandit.com
like 5 parts come up, none of which are a case saver.
