86 LT230 Issues
Old 06-13-2011, 07:21 PM
My91Ranger's Avatar
Default 86 LT230 Issues
Hey Guys, hoping someone can help me get my lt230 running right. Bought it at the beginning of the year and got it running, ran it a dozen times without issue until a couple weeks ago on the sand it cut it out and wouldn't restart. The exhaust got very hot and melted the paint off. The problem is it will only run under half to full throttle, will not idle, and still runs hot enough to make the exhaust pipe smoke. I have replaced the CDI module with another used unit, reset the valve timing to factory specs, cleaned the carburetor out completely, and verified that the timing is dead set on (didn't jump a tooth). Any idea's would be appreciated, as I am supposed 2 leave for another dunes trip in 2 days!
Thanks!
Old 06-13-2011, 09:52 PM
tomgodair's Avatar
Adjust the valves. And really make sure every jet in the carb is clean. Also, make sure you don't have an air leak in your top end.
Old 06-14-2011, 06:32 PM
My91Ranger's Avatar
I have readjusted the valve lash and checked the jets again. The quad will still only run only part to full throttle, will not idle, and the exhaust is real hot. Pretty much out of time to work on it now, but if anyone else has any idea's I would really like to get this thing running!
COFatboy
05-02-2020 12:06 AM
Jenn1
09-08-2015 09:16 AM
cody500ho
14
08-14-2015 05:03 PM
WesTech
11
08-11-2015 07:55 AM
Unzzy66
07-11-2015 10:01 PM
Quick Reply: 86 LT230 Issues
