A few Q/S 80 engine rebuild questions??
Took the engine out of my sons 2001 Quadsport 80 because there was a knock of some sort. I don't know if the knock was from the connecting rod bearing or the wrist pin. I don't have a shop manual. So I haven't tore it down yet. How difficult is it to remove the connecting rod from the crankshaft? I've rebuilt dozens of SBC's. Never rebuilt a little two cycle engine though.
Take all the help I can get, thanks, NYH1!
The knocking may be a wore piston and yes, get the top end off and see what the piston to wall clearance is.
Wiggle the rod side to side and up/down. Try to notice any movement with the exception of minimal side to side motion. That's normal.
I've not ever seen a piston pin brg go bad on these.
FYI: the good dr.turbo is correct in recommending a new crankshaft. By the time you buy the rod kit and get it installed, the new crank is only a few dollars more...And it's straight.
Splitting the cases (apart) is easy. Getting it together without binding the crank is the trick.
I use alot of heat.
I use alot of heat.
I use alot of heat.
I use alot of heat.
KimSJoh
14
07-18-2015 07:20 PM
