lt 230s namura piston help
Anyone use a Namura piston in a rebuild? My question is does it install in the same direction as the factory piston? Also how do you tell the difference between the top ring and secondary ring as they are shaped different than factory rings. my guess is that install is the same as oem. Any help appreciated
exmotocrosser
09-13-2019 06:12 AM
Quadzilla Heritage
09-25-2015 01:39 PM
