Carb help
Old 09-23-2011, 05:21 PM
suzukiitup's Avatar
Default Carb help
I just rebuilt my lt230. i got it started but only starts with choke on. The quad will run for 20 to 30 second then no matter how much gas you give it it stalls. Could a carb rebuild fix this or is it something else?
Old 09-23-2011, 06:48 PM
Knust's Avatar
Ceck your gas cap vent and vent on side of carb. Could also be stuck needle valve in carb or gummed up petcock
Old 09-25-2011, 02:35 PM
suzukiitup's Avatar
I took apart and cleaned the carb about 5 times and still doesnt work. Should i still do a carb rebuild?
Old 09-26-2011, 09:36 AM
richardw's Avatar
You need to do what Knust told you first, make sure there are no obstructions with the vents including the one in the gas cap, or just take the cap off and try to run it and see if that makes a difference. Next I would remove the fuel line from the carb and then turn on the fuel and see how it pours. Should come out in a steady stream the size of the hose.
Make sure the float is set correctly and clean every orifice in the carb with a can of spray with the straw on the end. When you spray it in one hole you should see it come out somewhere else, if not something is plugged.
I'm thinking you might have an air leak, if you can get it running again spray some carb cleaner around the carb and intake and see if it bogs down the engine.
Old 09-27-2011, 08:31 AM
LT80's Avatar
LT80 Expert
Is it timed correctly?
Old 09-29-2011, 06:03 PM
suzukiitup's Avatar
The cam chain sprocket marks are lined up right and the one on the magneto is lined up is there more marks besides those?
GregM
03-06-2018 06:53 AM
GregM
07-29-2015 09:41 PM
ghost civic
07-27-2015 03:15 AM
Aitch
07-21-2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Quick Reply: Carb help
