valves move
valves move
i have a 86 230s with a 89 250 motor in it
it runs perfect starts first kick as long as im just putting around when i take it out for a few hours and get on it hard it wont start back up once i turn it off
last time i kicked it for at least 30 min and nothing
took it home reset the valves and its back to starting up first kick
this happened 2-3 times
why.....how can i fix it
i have another 86 230s and i can do anything to it and it starts first kick everytime so i know they can handle it
Also, are you locking the jam nut for the tappet tightly? and you could have bent valves. check for cam wear, worn out lobes will throw off the valve spec too. alot of factors to check just in the valve cover alone and making sure the timing is perfect. i have built dozens of 230 engines and 2 lt250s engines, only difference between the 2 is stroke and bore size, and the 250s intake valve is bigger.
i opened it up looked around everythink looked ok...not really sure what im looking at
both locking nuts were tight
i reset everything put it back in it started up first kick so i took it out for a few hours and now its back doing the same thing wont start and feels like low compression..i can kick it without the decompression
Elkaholic
09-06-2015 02:44 PM
