LT230GE Idles, dies with throttle.
Old 07-27-2013, 01:26 PM
jackmonte1987's Avatar
Default LT230GE Idles, dies with throttle.
A buddy of mine and I recently got an 86 lt230ge in great shape for a few hundred dollars. When we got it it didn't run. I have since replaced the air filter, spark plug and soaked the carb/installed a new carb kit. The thing now starts with no problems and idles pretty well actually. The issue we're having is if we touch the throttle, 90% of the time is just cuts out. Sometimes it'll respond to the throttle and rev as usual but most times just cuts out for a second. If i restrict air flow (cover the air hole, or squeeze the tube shut) it revs up on its own as it should because it is being fed just gas.
I looked over all the diagrams of the carb and noticed there were 3 small pieces that I don't see in my carb. I attached a pic of the 3 parts that our carb is missing. They're titled "plate" "plate,needle" and "screw". Are these 3 parts needed to make the carb function correctly?, I can only assume yes but I wanted to get a second opinion before I went ahead and ordered this stuff.
Also I noticed that our air screw does not have a spring, o-ring, or washer on it. Could air be getting in through there?
The quad is 100% stock and the carb is adjusted to be stock as well. I Sprayed starter fluid around the intake boot to see if i could see a leak but everything seems to be sealed well. Any help would be great.
- Jack
Old 07-28-2015, 09:38 PM
brittle's Avatar
when I push on the gas my a tv chokes out? It will sit and idle. I cleaned the carb as good as my knowledge it is a 1985 lt230ge suzuki is this what yours is doing??
Old 08-01-2015, 07:59 AM
Bulgin88's Avatar
Try a new jet
Old 08-01-2015, 08:00 AM
Bulgin88's Avatar
And you do need those peaces
Polarisman1123
09-13-2015 10:06 AM
dwhipper61
08-27-2015 11:01 AM
Knackknack
08-19-2015 07:45 AM
cdoren
08-16-2015 11:22 PM
house1
08-09-2015 10:49 PM
Quick Reply: LT230GE Idles, dies with throttle.
