400 eiger
Will it start again if you don’t switch off, i.e. just wait a couple of minutes? If so, it could be a fuel problem, either the tank vent blocked, check by removing the cap when the fault is on, a sucking noise and the quad running OK with a loose cap indicates this, or the tap could be playing up, try it on reserve and prime. If it is an electrical fault, things are more complicated.
