need some help with my 91 lt250r
Old 12-28-2013, 05:55 PM
Suzuki Guy31's Avatar
Default need some help with my 91 lt250r
After buying this quad from a kid I bought a book and re built the quad. But since I've blown a head gasket. Now I'm looking at the piston inside the head sleeve and the back end of the piston is hitting the head causing a gauge in the top head. What would cause this? And does anyone know how I can fix it? Please help I'm going crazy! !
Old 12-29-2013, 02:27 PM
tomgodair's Avatar
I would either assume your rod bearing is done for if you didn't rebuild the rod or the more likely than not answer, the head was shaved at one time for higher compression and you probably need to go back to a stock style head. The previous owner might have used a thicker head gasket too.
tomgodair's Avatar
Also, make sure you installed the base gasket to the cylinder
Levi Enstad
09-26-2015 08:00 AM
Halffast17
09-11-2015 02:30 PM
LTqracer
Sport Quads
19
06-02-2004 07:20 PM
donpeter
04-04-2001 12:31 AM
Steve10
08-02-2000 03:32 PM
Quick Reply: need some help with my 91 lt250r
