Suzuki lt 80 clutch help please
Old 06-16-2014, 11:43 AM
Wnthunting's Avatar
Default Suzuki lt 80 clutch help please
Hello all... Is the front clutch on an lt 80 supposto be greased or dry? And also how do I get rear clutch plates off .. I got the first part with the weights off but the clutch plates are stuck. Should I use a puller ?
Old 06-17-2014, 06:15 AM
LT80's Avatar
LT80 Expert
From 87-2003 (or so) Suzuki packed the front clutch full of grease. Which hardened and caused damage. The newer LT's have no grease in the front clutch. I use just a dab of grease to help hold the roller in place durring installation..
As far as the rear, look at a fiche so you can tell me the real names of the parts. That way I don't advise wrong.
Old 06-17-2014, 07:35 PM
Wnthunting's Avatar
Thanks lt80 .. The part that I got off is the clutch assembly ( with the shoes) the part that I can't get off is the fixed driven.. Looks like it shod pop right off but won't budge
Old 06-17-2014, 08:47 PM
LT80's Avatar
LT80 Expert
The bearing is froze/stuck on the shaft. Been there..
Dare I say...heat gun.. Maybe a hot and cold or 2 will help.
They usually come off.
Old 06-17-2014, 09:23 PM
Wnthunting's Avatar
Ok .. Thanks for the help .. I guess I'll just leave it we'll enough alone for now ... It seems to be working fine .. Just wanted to take it off to clean out behind it .. The whole clutch case was full of dirt and stuff .. Thanks again for your help
roy.hawkins3@gmail.com
09-11-2015 02:35 PM
Minimod
09-10-2015 08:03 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
09-01-2015 11:59 PM
cdstang
08-31-2015 07:52 AM
Quick Reply: Suzuki lt 80 clutch help please
