Early 90's suzuki ltf250 2x4 custom built. NEED HELP
Hey guys completely new to this site and never really posted for help before but this ltf250 is not entirely a ltf250. What it is is a ltf 250 rear end(from engine back) welded to a hammerhead, or something similar, front end. Pretty awesome. It was done extremely well and looks like it's meant to be... Well almost. BUT I did not build this and picked it up two days ago for only $275! The engine was semi recently rebuilt and bored .40 over and a performance piston installed (so he said). He said it ran but it had a short, or wiring issue of some sort. No help. So first thing I did was pull the wiring harness off and re do all the connections. Plugged her all back up and got the neutral light to come on. After a bit more fiddling and a jump start she fired. And tI my surprise that engine ran like a raped ape. I indeed believe it was recently rebuilt. But now here is where we have the issue. First off battery is dead and no idea if it's good. After addressing some other small issues and going to fire her up again with a jump it wouldn't fire. Cranked like crazy but no fire. Tracked it down to a weak/ hardly any spark. Not the plug it's new. Now this is where I need help. I'm not exactly sure what year this thing is but from what I can tell it's an early 90's. So the weak spark... what do you all think? I'm thinking it's gotta be the ignition coil or the dead battery. Had the jumper cables hooked up and it cranked over just fine but little to no spark. So can a bad battery crank fine on a jump with still no spark. I know electrical systems can be tricky like that. Also would the mikuni carb be the stock one on an early 90's ltf250? Has a little **** (assuming it's the idle?) But not sure. Biggest thing is I need to get this darn thing to spark. Also would headlights not come on with a bad battery? Even if it's running. I know that's a lot but any help would be greatly appreciated. Thank you ahead of time.
Customer Service #1
05-15-2020 08:46 AM
09-01-2015 11:59 PM
