1986 suzuki quadrunner 230G valves help
Take the valve clearance down to 0.006" with the piston at top dead centre on the compression stroke, you won't be too far off at that and if the clatter goes you know that is the problem. I find a mild seizure can cause a sound like valve clatter as the piston clearance increases at the skirt and creates a lot of piston slap. Also Honda 350s sometimes get loose valve seats which make a racket, don't know about your model.
09-01-2015 11:59 PM
