Suzuki lt185 will not start
Old 02-15-2016, 02:00 PM
Greasemonkey2067's Avatar
Default Suzuki lt185 will not start
I have a mid 80s Suzuki lt185. I cannot get it to start for the life of me. I have great spark, compression, I have cleaned out the carb, I spray starter fluid in it when I crank it over, I am also using a drill to start it. After all this it doesn't even act like it wants to run, any suggestions?
Old 02-15-2016, 02:19 PM
Fasteratv's Avatar
Pop the carb bowl drain to ensure your getting fuel into the carb ( might check petcock as well ). Also, if the valves are tight, sometimes very very hard to start.
Old 02-15-2016, 02:23 PM
I have fuel in the bowl, and my rocker arms have slight play but I'm not sure how to check to see if the valves are too tight.
Old 02-15-2016, 03:11 PM
I also noticed that on the tdc of the compression stroke there is a bit of play where the flywheel will move but the piston doesn't
Wayne87
1) Engine problems..
01-25-2020 10:59 AM
TaoTao110D
01-21-2016 01:23 AM
frankmako
01-17-2016 08:51 PM
Mattirons76
01-17-2016 12:01 PM
ritchierich
01-13-2016 02:57 AM
Quick Reply: Suzuki lt185 will not start
