Suzuki lt185 pickup coil
Old 02-15-2016, 10:22 PM
Greasemonkey2067's Avatar
Default Suzuki lt185 pickup coil
Is it possible to retrofit a late 90s model pickup coil onto an lt185? Mine is broken and the only reasonable priced ones are the newer ones.
Im in the process of retrofitting a gm ignition module and coil on the quad and I need to use this pickup to make the spark go off at the right time.
Old 02-16-2016, 05:18 AM
Old 02-16-2016, 09:59 AM
That's similar to the ones I'm looking at, the original is a one wire coil with the ground going through the engine, that looks like it runs the ground wire out like I need it to be. I'm going to do a little more research before I pull the trigger
Old 02-16-2016, 10:16 AM
Well I read about that part and it seems like its a direct replacement, I may try that when my paycheck comes in
Old 02-16-2016, 11:40 AM
Hope it works out for you. Post your results as it may help others.
Old 02-16-2016, 12:28 PM
Will do!
Whitelx1
02-29-2016 12:54 PM
Greasemonkey2067
02-17-2016 12:54 PM
MapleNeil
02-15-2016 05:22 PM
Greasemonkey2067
02-15-2016 03:11 PM
Zachery Allen
02-12-2016 08:09 AM
Quick Reply: Suzuki lt185 pickup coil
