Choke Issue
finally got choke fitting and got it installed the way you suggested. it stayed in, but now when I get it up to about 12-14 mph with the throttle it runs sporadic. If I push throttle more it wants to bog down and almost dies. I saw a post that these units had a vacuum prob and to try pri or res on the pet ****, that did not help. Any suggestion?
Retrace your steps on the carb and make sure jets are open and all orifices are blown out. You can always try a remote fuel bottle to the carb also to see if it runs better which can determine if it's a vacuum problem or not. Or a simple mity vac on the vacuum line to see if it's working correctly.
reply
Revisited carb and found it had plugged back up somewhat. recleaned When I revisited if found the starter jet clogged and then when went to put the pilot jet back in it did not seat at the same location. I backed it off the same number of revolutions as it was in and I noticed the needle sticking out into the air stream, it did not do that before. Is there a specific depth of the jet??? I made it flush for the time being. Then the choke spring zoomed out into the garage somewhere.Now another weeks wait for parts.
Scottkrone2
Technical and How-To Articles
03-04-2016 06:57 PM
