Question
First thing you will need to do is get an airbox and filter for it. Looks like the prior owner ( or someone ) replaced the box with a automotive style radiator hose.
Look on the engine.....not sure which side ( probably the right side ) but you should see the engine size CC's.
The two hoses look as if the go to the carb...atmospheric vents.
It's a 280cc and the lines do run to the carburetor. The one looks like it was attached to something. It's shaped like it would have a fitting in it, the other is broke off. If there is something I need to put there I need to know what it is so I can find one. As for the intake I'm gonna take the white plastic pipe out and get a radiator hose and rUn it from the carburetor all the way out the top and put a filter on top.
Ckieffer29
04-01-2016 04:49 PM
1973bronco
02-13-2016 07:45 AM
