Lt80 melting starter relay
I just picked up an lt80 that was apparently having starter issues. I hooked up a battery and it just clicked. So, I swapped in a relay from a parts bike I have, and it did turn over but was pretty slow. After cranking it for a while the relay started smoking. So I just bypassed the relay with a jumper wire and that wire started smoking too.
Could there be a short or something in the starter, or another problem I'm not thinking of?
If I can't think of an easier solution I'm going ti put in the starter from the parts bike.
Yup, I spent a couple hours putting in the starter from the parts bike, which included cleaning out the carb and installing a new Uni filter since I was in there. It wasn't too bad, I was able to stand it on end, and strap the front end to the ceiling. Now she's cranking like a champ. Before there was a horrible grinding noise too, that I was hoping was just the starter, which was. No melting wires either.
Now I just need to get it running. Hopefully not too much trouble.
I think I need to find a good shop in the area and get my piston, cylinder, and head looked at. Need a new gasket set too.
trouttracker
01-03-2016 04:48 PM
trouttracker
01-02-2016 02:15 PM
