Suzuki 500 King Quad power steering fault
Old 06-30-2016, 02:05 AM
Default Suzuki 500 King Quad power steering fault
We got a 500 KQ in for service this week, the owner has been complaining of an intermittent power steering fault for a while. We fitted the device to fetch up fault codes, and got the EPS light flashing:- two long, two short, two short, one long. Long pause then two long, four short, one long. Trouble is, our workshop manuals are pre EPS so we don't know what these codes are. Tried the local Suzuki dealer, he put it on computer and nothing came up, the computer only reads engine management faults, he hasn't a book with the EPS codes in either. He tried ringing Suzuki, all technical staff are away on a course. Does anyone know what these codes mean?
Old 08-26-2017, 06:10 PM
TimRowell's Avatar
Default 500 quad, same problem, clean all fusible links
i
dirty fusible links
Old 08-27-2017, 02:27 AM
I apologise, I did fix it myself and forgot to put the "fix" up on here. It was the battery live terminal broken. It was made so that part clamped round the wire's insulation, and part round the copper wire, the part round the copper had cracked through but was held touching together by the part round the insulation. Surprising that enough amps got through for the starter, but not enough for the power steering, except when the engine was revving, in which case the alternator powered the steering, which is why it was intermittent.
munceyman
04-28-2016 10:21 PM
gadawg31
04-18-2016 01:33 PM
Quick Reply: Suzuki 500 King Quad power steering fault
