07 Suzuki ltz 50 dynatek CDi - help
Old 07-25-2016, 03:57 PM
Skylar1's Avatar
Question 07 Suzuki ltz 50 dynatek CDi - help
I have a o7 Suzuki 4 stroke ltz-50 & it has a dynatek CDi & it runs fine on limit 1 which is top speed rpm curve but will not limit down on limit 2. -3 or 4 which would be 4 mph the slowest setting - CDi tested fine at dynatek & they sent a second test unit both do same thing - the spacer is out of clutch but & no other mods does anybody have on in their bike that works ?
Old 08-02-2016, 07:26 AM
LT80's Avatar
LT80 Expert
That machine is slower than snot in the winter.
Curious as to why you want it slower.
How old/big is your rider?
Old 08-02-2016, 09:20 PM
Skylar1's Avatar
She's 3 & 30 lbs just starting out want to get it as slow as it can go
Old 08-03-2016, 05:25 AM
If the Dynatek limiter works on counting the number of sparks per min, and cuts out when it gets to a certain number I can't see any way it could fail to cut the speed. However if it measures how much power the alternator is producing and cuts the sparks when it reaches a certain level, a faulty alternator may never reach the cut out power. Find out which way it works from Dynatek. A simple work round could be to fit a throttle stop like the old LT50s had.
Old 08-03-2016, 09:24 AM
LT80's Avatar
LT80 Expert
Ummm has she had a powerwheels?
Old 08-03-2016, 09:14 PM
Skylar1's Avatar
Ya she has power wheel - just trying to get the ltz 50 dialed in that CDi not letting the bike limit down to 4 mph on limit 4 which it should with a flick of a switch - & thanks I know could just us the throttle limiter screw but would like to use CDi
Old 08-06-2016, 06:46 AM
LT80's Avatar
LT80 Expert
How about a pic of the lil gal on her z?
lucman
01-23-2017 08:46 AM
mixmastamm
10
05-16-2016 09:19 PM
Brett Van Sickle
05-07-2016 08:59 AM
munceyman
04-28-2016 10:21 PM
Quick Reply: 07 Suzuki ltz 50 dynatek CDi - help
