Suzuki LT80 QuadSport reset button?
My Suzuki LT80 QuadSport starts and then stops within an intermittent short amount of time.
We will start it ride down the block just a couple minutes and it just dies.
It wont start again till I press the little reset switch.
Any ideas what's wrong with it?
90's I believe...I have an earlier LT80 and it doesn't have the button...
Not sure about it "seizing up"...they seize and that's that...shutting down after warming up sounds electrical to me, but checking the compression is always a good idea when the motor is acting up...
"they seize and that's that"
I fitted a used 3hp B&S engine to a bale elevator on a farm, it would stop after 5 to 10 min running then restart after cooling down. I was sure it was the magneto, so fitted a new one, didn't cure it. Then noticed it was a little stiff to pull start when hot, took it apart and found some prawn had fitted a new piston but left the oil flinger off the big end cap, by that time the main bearings were shot from oil starvation.
