03 LT-A50 top end rebuilt wont run
That motor was used for decades in scooters all over asia. Its most likely a china knock off and the jetting will be different. May want to check it over before install. So far the china engine kit is working just fine for my sons 50. In fact, just got in from riding, my son pretty much rides it wide open throttle unless he is turning.
The pulse draws the fuel from the carb (think vacuum)...weak pulse will mean little or no fuel...if the pulse is very weak normally that points to a cylinder base gasket or a crank seal being bad (sucking air from somewhere else other than through carb)...hopefully this is not the case as you just ordered a new carb...
I'd also check the intake and ensure nothing is amiss there...
#15
Yes, It works just fine in prime. Its just like keeping a petcock in the ON position, if the float is working correctly the motor will not flood or leak fuel, unless you are standing it strait up to load it in your pickup. My trailer will be done Friday, so I wont have to worry about that any more.
#16
#17
Ok well no luck with carb. Its the exact same. Only fires for a few seconds with starting fluid sprayed directly in cylinder with exhaust removed.. noticed when it does fire air is coming out of the pull started area cause i can see the fibers moving on the rope.. must be a internal leak. Gona have to tear it all down to replace gaskets and seals i guess. Anybody recommend any good web sites to buy those?
Robert.unger
1) Engine problems..
03-04-2018 02:33 AM
TaoTao110D
01-21-2016 01:23 AM
