LT 230s - Running hot - I think
Old 08-25-2016, 10:03 AM
Kris Keith's Avatar
Default LT 230s - Running hot - I think
I just bought an LT 230s. I got it started and noticed a clicking/ticking sound at low idle. I am assuming a valve adjustment will take care of that. It seemed like it was running hot so I used my temp gun and shot temps around the head. It was really hot (over 340 degrees) near the spark plug and hotter than it should be (high 200s) on the rest of the head. I know it is oiling some as I can tell from the movement of oil in the check oil window and I removed the valve cover bolt while running and oil sprayed everywhere. Do you think the valve spacing could be causing this or what other things should I check? It seems to run fine and doesn't smoke but I am concerned it is about to burn up.
Old 08-25-2016, 10:29 AM
Scooter86's Avatar
Knows Old ATV Questions!
I think you are on the right path checking valve adjustment. I would also check jetting/check your plug. It could be a little lean or someone may be running a hotter plug than stock. I really don't know what head temperatures should be, but being an air cooled engine I would suspect it would run hot just idling for extended periods.
Old 08-25-2016, 03:59 PM
DirtDevil101's Avatar
I don't think it'll burn up...just loose power...air cooled engines are known for loosing power when they get hot...definitely diagnose the ticking...ticking is bad...
Old 09-02-2016, 11:54 PM
Kris Keith's Avatar
Is there anyone that can take some temperature readings of their LT230s on the head?
Old 11-08-2016, 11:41 AM
jel08270's Avatar
Kris do you have a stock exhaust on it??? I had my Suzuki exhaust clogged with RUST n it would do the same thing yours is doing.Take it off and let it run for a bit n see if it runs hot.
razman_07
03-13-2016 04:06 PM
maveikfe
02-15-2016 08:07 PM
Timbo2500
01-24-2016 11:17 AM
jm1
03-23-2000 07:43 PM
Robert Venable
08-04-1999 11:36 AM
Quick Reply: LT 230s - Running hot - I think
