05 700 KingQuad Electrical Problem
I pulled a real bonehead move and now need some guidance to fix the issue.
My Kingquad has been sitting for a few months and the battery was dead. I hooked a charger up and left it overnight on 2amps. Next day it still wont start but the lights come on and the instrument panel lights up but there isn't enough power to engage the starter so I figure the battery is toast. I took a good battery out of one of the other quads and installed it but when I turned the key on the instrument panel would not even come on. I look at the battery and see the terminals are reversed on this battery. I hooked it up with reversed polarity . I checked the fuses under the seat and they are all good,oh oh. Now what have I done.
Can anyone tell me where to look next. Help would be appreciated.
The main fuse is on the starter solenoid, with luck you will have blown it. Just hope that you haven't blown the ECU or regulator as well.
If you don't use your 700 two or three times a week, it is imperative that you fit a battery isolator switch like those used by racers, as Suzuki "laid a large egg" with the electrics on the 700 and chose an ecu that takes a fairly big current even when switched off, so it runs the battery down quickly if you don't run the engine to re-charge it regularly. They also messed up the wiring so that maximum charge is about 13V, so it takes a good long run to re-charge it.
Thanks merryman, I will check it out after the weekend. We have our whole family here for the long weekend, so for the next few days it's all having fun with them. Although I have had to make repairs on some of their quads already but that's ok because it keeps them happy.
Greg74, this quad sits for very long periods without use, ever since I bought a newer one, so the battery usually goes dead. I replaced the stator on it last year but probably only rode it once since then. Maybe I should put an isolator switch on it. I've also noted it needs a full charge to fire up. This machine has been an awesome quad despite the beating I used to give it.
After the family left I checked the quad again and found another fuse near the battery. It was a 30Amp one and it was fried. Put in a new fuse and the panel lights up again but I think the battery it shot. Even with the battery charger hooked up to the battery the starter won't engage. Going to try another battery before getting another battery.
Thanks for the help and I will report back once I confirm it was the battery or I find something else.
I have a 2006 or 05... KQ 700. I had to have the ECU flashed by the dealer, to stop the battery from going dead in a shot period of time. This atv will sit for a month sometimes, & will start right up. check the dealer for service bulletins on your unit. now it never drains down after the reflash.JFI
reezy
02-21-2016 06:31 PM
