Any one know what this engine is.
I was thinking that also. But has the LT250R run a oil pump? I didn't see any engines on ebay with the oil pump in them and the oil tube going into the side of the intake.
Just been told it also might be a 84 TS250XE
CYLINDER (MODEL E) - TS250XE(E/G/H/J/K) E 1984 - TS250XE(E/G/H/J/K) - - TS 250 X Suzuki - Genuine Suzuki spare parts
Think we may have worked it out as I just seen that the LT250R has not got the temperature sensor in the head like the TS250 has also the LT250R has not got the oil tube going into the side of the intake manifold. From what I can see the LT250R runs no oil pump.
But I cannot find a wire diagram that is the same colours as what I have. mmmmmmm
Inside that thing attached to the carb. The shaft sticking out is spring loaded and the part inside on the left is also spring loaded. Asked granddad and he thinks its some type of air vacuum valve. One hose goes into the engine side of the carb and the other is lower on the carb maybe going into bowl area or into air filter side of carb.
Couldn't see any thing in the parts diagrams online about this part.
Any ideas?
Any ideas?
larrypwilliams@gmail.com
08-16-2016 08:56 PM
