What flavor case half sealant?
Getting ready here to reassembly my engine (LT230s) and cant decode what Suzuki is calling for sealant between the case. The book says Three-4 bond but this doesn't compute to anything modern day part number, nor can I fine any reference to Three-4 bond (written out exactly like that in the book) and want to make sure I only do this once. I also noted the book calls for a different sealant for the rocker cover Suzuki Bond 1207B but it is a silicon based sealant and know that's not what I want between the case.
I was thinking Honda Bond HT, Ive used this on several Honda case halves and never had a problem but Im a purest and want to know what Suzuki used, anybody know?
https://www.amazon.com/Three-Bond-Li.../dp/B0012TUVAW You can get this at many cycle shop or even Permatex Grey at most auto stores is just as good.Permatex RTV silicone gasket maker 82197 - Read Reviews on Permatex #82197 Permatex sealant is closer in application and in application to the old Threebond 1104 that's hard to find anymore. Several other Threebond numbers out there ,but the 1194 is what we got in replacement to the 1104. Our suppliers(Tucker Rocky,Parts Unlimited) said it was discontinued because it had lead in it. Suzuki bond is basically the same as Honda bond,
yamabond,etc. Possibly could have been made by Threebond or even Loctite Corp as far as I know..Even Threebond has a 1207b/c sealant. https://www.amazon.com/Three-Bond-12.../dp/B008BYPRRI
With that said 99.5% of people use WAY too much sealant and thats most of the problem.
Thanks for your input! Ill report back with my findings.
Absolutely.. Especially the old red sealant that really shows the mark of an amateur sticking up around aluminum cases and covers.. All you need is a good bead of grey around engine cases,covers and then assemble. Once any excess has dried if you're really particular on how it looks on cases,etc you can either use a razor blade to remove any excess or just rub it off with your fingers and looks like a factory job.
