2005 LTA50 Running @318F
my kiddo's LTA50 ran hot from the second I picked it up used, Just figured poor piston to cylinder heat transfer from a worn top end was the problem. Got a fresh top end (properly bored with wisco piston) installed and its now running hotter! Iv never seen a air cooled 2 smoke run so hot! I shut it down after it starts making bad noises- Any ideas? see video:
When I got it back from the bore shop I just eyeballed the ring end gap looked ok, piston had good room too- stuck my thumbs on the skirts halfway up the bore and it clinked back and forth well. I had some trouble with the rings wandering off those locks on the piston, would I be able to get the cylinder on if the rings were over one of those position pins?
