LT80 Wont rev up
LT80 Wont rev up
Not sure on the year quad I have here, but it is an lt80. The thing will start up and idle, kind of rough/low. As soon as I hit the gas it bogs out and may stall. Sometimes I can feather the throttle to coax it up to speed but not always. I have put a new carb kit in it, cleaned the carb several times, new plug, checked compression at about 130lbs, removed exhaust to check for restriction, checked piston condition through exhaust port, new air filter, checked fuel flow through petcock, checked vacuum and vent lines, replaced fuel line. Don't know what else to check, timing maybe? Nothing really happened to it prior to this. I pulled all the shrouds off to clean out a mouse nest infiltration, put it back together and wouldn't run. Is there any wires a mouse could have got to that would cause this?
So, I figured it out. I reread your post and went back to the reed cage, which I missed the first time I read it. Pulled the cage out, and there was a piece of an acorn that was logged between the reed and the cage, holding it open. Stupid mice, cant believe what they get in to. Thanks for pointing me in the right direction.
Brink - you're gonna want to listen to Jack's advice and pull the clutches...even if you think it's running fine, there could be more to have...I recently got 2 of these things, neither's clutch had been services...ever...
Glad to hear it was a simple fix (sorry you pulled the flywheel first)...most forget just how important the reed cage is on the mighty 2-stroke!!!
