2008 LTZ400 sputters pops and dies
Hello all! New to the site... Looking for the possible answer behind my smallish problem. So I'll be riding my quad for maybe 45 mins or a little longer and everything is fine... Then for some reason, it will start to sputter and pop a little and then immediately die. It doesn't seem too bad because directly after I try and start it and can and it runs fine after that. May happen again if I ride for a few hours but not more than once or twice in a 3 or 4 hour ride. Just curious as to what it could be. I was thinking it could either be the spark plug or the carb needs a good cleaning but wanted more opinions as I'm not too mechanically inclined... Also the weather I'm riding in is around 30-40 degrees Fahrenheit. Thanks for any and all responses!
Start simple first...which is a good carb cleaning...there may be debris in the bowl that gets sucked up into the jets and is just large enough to cause partial fuel blockage, but then clears itself...
Electrical can be a beast to chase down, so let's hope it's a dirty carb...
I'd validate the fuel flow after the filter looks good...if it started showing these symptoms after a new one was installed...
It could be electrical (including plug), electronics have a mind of their own and I've seen too many strange symptoms to ever rule them out...however, they can be difficult to track down, so I always start with the easier/cheaper potential issues first...
