03 suzuki eiger no spark
Yes, but the neutral light won't come on if the ignition isn't on. So, does the reverse light work. Faulty ignition switches, slack battery terminals, blown main fuse (on the solenoid) are all causes of ignition circuit failure. If all other circuits come on with the ignition, there is a relay for the neutral light circuit, can't remember if it is the one by the voltage regulator or the one at the side of the fuse box but it could be a fault with that.
