1986 lt250r
Old 02-25-2017, 11:46 AM
Trevor Tate's Avatar
Default 1986 lt250r
Aleight guys got a 1986 lt250r just put new clutch all back together all except the clutch rod im not sure how i get that lined back up with the pressure rod inside the basket? Any info would be great
Old 02-25-2017, 08:21 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Try suzukiquadracerhq.com
I'm sure those guys can help.
Old 03-21-2017, 10:48 PM
Pyromaniac's Avatar
Default Clutch
Hi Trevor. Pyro here. Pull your clutch cover back off & turn the rack portion,(the teeth)( The piece sticking out of the clutch basket) toward the hole that the pinion goes into. NOTE : Should have mentioned this first. Be sure you have your clutch adjustment backed all the way out @ the lever @ handle bar & @ the clutch pinion.Be sure the 2- 12mm nuts are backed off also. The lever should then be @ approx. 45 deg. to left of the pinion hole. Be sure to adjust back to original position @ pinion & .120-.180 @ handle bar lever. This is factory spec. I adjusted mine to where the clutch felt comfortable to me.
Last edited by Pyromaniac; 03-21-2017 at 10:56 PM. Reason: made easier too understand
DocShady
02-05-2017 04:35 PM
Holcomb
01-16-2017 08:11 PM
Brandon Asbury
01-11-2017 09:15 AM
Quick Reply: 1986 lt250r
