Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
KFX400 idle problem
Old 01-18-2009, 02:35 PM
JaysinDesignz's Avatar
Default KFX400 idle problem
I've got a 2003 KFX 400
Each time I fire up the quad it will not hold an idle after running it. I pull in the clutch & it dies. After running for maybe an hour it will finally hold an idle.
Yesterday I tried to trouble shoot the problem & noticed the fuel filter isn't hold fuel? I tried priming the system & still trickles slowly in & runs out faster that it runs in (on idle) I pulled the fuel line out on the outbound flow side & the fuel poured out) Not sure if this has anything to do with the problem. There is no real throttle response issues within that hour of running.
But, while 1st running as long as I have the quad running & giving it throttle it runs fine. It's just when I pull in the clutch it dies. Then again after about an hour its running perfect.
Old 01-21-2009, 03:21 PM
You guys rock with all your help & tech knowledge. Thanks I'll be sure to be back around this BB
Old 01-21-2009, 03:28 PM
scootergptx's Avatar
Supersock
Hired Gun!
Well, I got to admit, it has me confused.
But hey, since you aren't coming back around, I'll just keep it to myself.
KimSJoh
14
07-18-2015 07:20 PM
ranvette
07-12-2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Robbbb55
07-08-2015 02:11 PM
MNatv89
07-07-2015 11:36 AM
Quick Reply: KFX400 idle problem
