polaris trailboss stalls when I hit puddles?
Usually it's water that can ground out a plug cap,splash under the front panel and ground out a coil or cdi. Just blow out the plug and cap area,all connectors with an air gun or just let every thing dry out. Then use electrical grease at all electrical connectors,inside and out side the plug cap a little and this should help. Make sure no water is getting into the air box also.
