2004 sportsman 600 twin
Hello everyone i`m new here And am looking for some help. My reverse limiter switch is not working and iy also works my speed o unit, Tach, trip meter nothing works. Bought a new speed o unit and speed censer and still nothing. Everything was working but the speedometer then lost everything. does this have a fuse some place. it`s driving me nuts tiring to figure it out. Thanks for any help
Sounds like your problem wasn't in the speedo itself but the left control switch if you can't toggle through the menu.You can try some electrical spray in the cracks and crevices of the switch and see if you restore function of the yellow button. Plus a check of the wiring and connectors leading into this switch are common problem areas also.This button along with the rest of the switch has too many functions that can fault. If you narrow it down to a faulty switch Partzilla shows to be cheapest at 78 bucks in the cart.4011835 CNTRL-LH,HI/LO/OFF,2P,SEP $78.38 Plus check speedo connector itself for any pins that may have pulled back,not making good contact. IF you're not getting power at all to the speedo or ignition switch,lights,etc,could be a simple cheap thermal circuit breaker. Located in a plastic pouch up from the battery. See if you have voltage going in and out. If not,slice the pouch open and check the breaker,could be corroded. You can get these at any auto store for about 7 bucks.
01-14-2016 03:11 AM
