2006 Kodiak charging system
Hello, I'm new here so I'm not sure if I'm in the right place. I have a 2006 Kodiak 450 that wont spark. I've already tested the regulator/ rectifier and it's bad. I need the specs for the stator to make sure I can fix the problems. I've had similar problems with it so I want to check everything to remedy the problem. Thanks for any help.
bwalker2
06-23-2016 12:23 PM
