Used U-haul trailers
Honestly stay away from them unless you spend the money and have another shop look at them first. Uhaul stuff is abused pretty much on a daily basis with little to no maintenance done to them. Do some searching and you will see the failure rate of things due to no maintenance. Last time i rented a car hauler the brakes did not even work on it.
What makes them 'ideal'? Because they are enclosed? because they are from Uhaul? Why would they be cramped? They come in 4 different sizes. Wouldn't you just get the size that best suits you?
Just because their is no motor or trans does not mean it could not be expensive to fix. I have seen them with cracked frames. If u don't know what your looking for its easy to hide. If they have had a major bearing false and damaged the axle surface and just tossed in new bearings without replacing axle. Their are lots of little things that can really add up in price. Also remember these are high milage abused trailers. A person would be better off buying a private used unit. The chance of high milage and abuse is much smaller. Unless you can pick up a uhaul for a couple of hundred I would not touch it.. I will not even rent from a uhaul now
Amazing what some people will sell as good.. Definitely a buyer beware world out their. At least when i sell something its eater in good shape or i will disclose everything wrong with it. Just like a old truck i sold. had a random steering issue and would lock up when turning. Told the buyer about the issue. they bot it slapped some paint on some body work i had not completed and sold it. Truck is now a write off as they did not tell the person they sold it to and he smashed it up..
badgerboy1
09-26-2017 06:11 PM
