Loading ramps
Loading ramps
I need a pair of ramps I can trust. Can anyone let me know about them. Are the folding ramps ok or should I stay with arched ramps. I have a Dodge dually 4x4 that sits up fairly tall stock. I know I should stay with the 89 " ramps or so. My machine is the 2012 Polaris Sportsman 400 and I am fairly big at 300 lbs. Been seeing them for about 159.00 or so.
I've got a Nissan Titan that also stands pretty tall. I got a set of bifold ramps that are heavy duty. I got them when I had a GMC 2500 HD and cut them down to fit in the 6'6" bed. I've never felt they were too short or to light duty. Mine are two 12" aluminum ramps that are adjustable width-wise. They're joined by two rectangular tubes that have holes so you can adjust the width. I highly recommend joined or folding ramps. I've had a couple near-mishap dealings with ramps that aren't joined together and wouldn't go back to them. I had got them at Cabelas but I can't find them for sale on their website anymore.
I used to have an Oxlite ramp. The longest one I see is 88" and the angle won't be as steep as the shorter ramps. They'll easily fit in a 8" bed but may be more than you want to spend. ATV Ramps For Sale
They are all safe if you use tie straps so they do not kick out, also go up in low with 4wd on.
Here's an interesting product I just found. It won't work on all types of ramps but it eliminates having to use a strap of any kind. The ramps simply fit into the lip and can't slide out. https://jet.com/product/21ac20ad4ba4...oC4hoCjk_w_wcB
