Polaris sportsman 500 hi hot check engine
So I was riding my 04' sportsman 500 ho the other day. I did take it through a mud hole or two and rode her pretty hard all day. Long story short the check engine light comes on now and reads hot even before I turn the key over. I've tried cleaning out the front and back of the radiator and in jamming the fan and it doesn't seem to help. Could it be a censory issue? Any help would be much appreciated. Another thought, if the fan had gotten jammed, which it was, and couldn't come on when it should have, could it have tripped out the censor so it just reads hot all the time now? Not sure what to do, if anyone can help me out it would be great. Thanks guys.
See if the wire is still connected to the temperature sensor on the head. Item#2.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If the fan is ok(you can run 12 volts direct to it to check) and still kicks on and off,possible that the temp sensor may have just shorted out showing hot at all times.It completes the ground path for the hot light. You can test it with an ohm meter. Check resistance when engine is cold. Should show at least some resistance,then goes down as the engine warms up. If the sensor zeros out when grounded,just replace it. Plus not a bad idea to raise the front end,leave the radiator cap off and run the engine until the fan cycles on and off several times to purge any trapped air.If the fan doesn't kick on and off,majority of the time it's the radiator sensor. Item#21 .http://www.cyclepartswarehouse.com/f...2004&fveh=5632
Ok so I've done everything u mentioned above and at this point everything checks out. So unless I misread something you posted above, it leads me to conclude that the sensor chip has gone bad. Would that be a good assumption? If so, my only other question would be if you know the exact part I should order for my 04' sportsman 500? Thanks again for the help.
whitty
67
02-24-2021 02:52 PM
Schneider
06-04-2015 11:37 AM
05-27-2015 11:15 AM
SOLOLUCKY
05-25-2015 05:25 AM
