O8 Sportsman 500 EFI battery light / not charging.
Old 08-06-2016, 04:10 PM
steelhead loco's Avatar
Default O8 Sportsman 500 EFI battery light / not charging.
Battery Light and quad not charging. No blink codes showing. After a lot of reading (this forum) and copying and pasting to word I have done the following:
Key off current draw Neg. term to Neg. battery wire .01 DC Amps.
Charge Battery to 12.7 Volts start quad check across terminals 12. 2 volts
Run Stator check 44 OHM's all three legs, all three legs to ground OL digital Multi Meter. Start quad check AC volts, Idle 18.5 all three legs, at somewhat high idle ( no speedo/ display) 53 DC Amps all three.
Was about to post here and ask how to check the regulator/ rectifier and decided to clean and check all battery / solenoid connections and also look at the fusible links. Glad I did here is what I found three shorts thru wiring jacket ( blue .08 fusible link ) going to the solenoid.
Lastly I want to thank OPT and others who post help and info here as this old fart would of been very lost without it. I am also guessing regulator/ rectifier needs replacing ?
Old 08-08-2016, 08:18 AM
If it's not charging at least 14 volts at and idle,then most of the time the regulator is the the problem. All yellows from stator should show some resistance between each other and no yellow to ground zeroing out.
toonces
03-14-2016 10:42 PM
rjarnold1987
03-07-2016 06:23 PM
Rluckie
03-07-2016 10:53 AM
chuck1177
03-06-2016 02:23 AM
JoeNewBee
01-25-2016 09:44 AM
Quick Reply: O8 Sportsman 500 EFI battery light / not charging.
