Suzuki Eiger I need some help!
Old 10-18-2016, 03:06 PM
whitemtn's Avatar
Default Suzuki Eiger I need some help!
I have a Suzuki Eiger. It is hard to start and when it starts it will idle for about 30 - 60 seconds then it will die. It was siting for about 2 years and the carb was really gummed up. I took off the carb and cleaned it with carb cleaner and an air compressor. I also took the spark plug off and it was black.
Also, the pull start is hard to pull sometimes it is stuck and i cannot pull it, but electric start does work.
I am wondering what the problem is.
Old 10-18-2016, 03:17 PM
Fresh gas,good flow to the carb? Still sounds like a jet could be stopped up. Plus my I'm not a believer in just cleaning a carb if gummed up after sitting 2 years with the gas we get now days.Quality Shindy rebuild kits are cheap enough and will make sure you only have to go into a carb only once. Shindy Carb Carburetor Rebuild Kit Suzuki Eiger 400 LTA LTF 4x2 4x4 2002 2007 | eBay
Old 10-18-2016, 03:25 PM
whitemtn's Avatar
Ok. Ill try that.
I put fresh gas in and it was flowing out when i took the carb off.
Thanks
