help..... starter goes but spins backwards!!!
Originally posted by: Turtler
You have the wiring switched around on that starter most likely to have it run in reverse.
i was just out in the garage, batt is hooked up right, solonoid is hooked up with positive... brand new back relay.. newer warriors only got one..relays are on right,
also the quad is a bit harder to push forward...also note i never unhooked any of the connections.. cept batt and starter and relays
yes i'm sure its going backwards...if it wasnt then the motor would turn over.... think i figured out y..suprized no one suggested it.. when i had the starter off it fell apart.. i must have stuck the brushes in backwards... and its reveresing the polarity of the magnets....
i'm getting ready to mess with it now... just thought of it..... later
