is there a noticible power increase on the wolvy with a hmf utility series exhaust?
From what I've seen and heard, If you just get a pipe you will be back to about stock, due to the loss of power from your 25's. You might consider a new filter, and rejet. Hmf will give you some good gains, but not enough by itself. Then again you have to be the judge of what is enough for your riding style.
The key to realize power with a pipe add on is jetting. Correct jet tuning is critical. A bike with a pipe that is not jetted right may run worse than it did bone stock.
A good slip on, a less restrictive air filter, and the right jet setup will give you a decent gain.
Mojave250A
07-11-2015 10:38 AM
