1996 warrior rocker arm specs
Old 11-08-2012, 07:24 PM
Jmuddin284's Avatar
Default 1996 warrior rocker arm specs
A buddy of mine brought by his warrior a couple weeks ago with a hole in the head and only part of the intake rocker arm. I welded the hole up in the head and ordered new gaskets and a rocker arm. I don't have a manual and can't seem to find what size feeler gauge to use to set the rocker arm or the proper procedure if it's anything besides that. I am also needing the torque specs on the head bolts. If anyone has either or both of these specs or techniques I would greatly appreciate hearing what they are!
Old 11-09-2012, 06:25 PM
95wolv's Avatar
should be .006 for exhaust and .004 for intake, dont know the torque specs
Old 11-10-2012, 08:16 PM
Jmuddin284's Avatar
thanks for the reply! I ended up setting them with a piece of paper... I figured it was about .004 or so and I knew the exhaust side is usually a little more gapped on most machines so I did a loose piece of notebook paper. The head bolt torque specs are 29ft lbs though. but I got it running and it runs great! Thanks again!
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
raman8tor
09-20-2015 07:35 AM
chewy78
09-08-2015 10:37 AM
Quick Reply: 1996 warrior rocker arm specs
