99 big bear 350 valve adjustment and oil???
Old 11-12-2005, 05:03 PM
sleddood's Avatar
Default 99 big bear 350 valve adjustment and oil???
Used the seach and didn't find a definitive answer on valve lash specs. Someone said that the specs are sometimes on the air cleaner lid, didnt find anything there. Also, what oil does everyone prefer for the 350? It's got a plow on it and works pretty hard during the winter.
Old 11-12-2005, 06:06 PM
bberck's Avatar
I adjust the valves on my 95 Big Bear the same as my warrior which is intake .06mm-.07mm and exhaust .16mm-.20mm. Not sure if the Big Bears should be the same as the warriors but was told on a forum somewhere they where and they big bear runs good.
Old 11-13-2005, 12:55 AM
hondabuster's Avatar
I think the owners manual spells out what oil to use. Should be 10w 40, most of the year and 10w 30 when it gets very cold. It will also specify SG oil.
The oil shouldnt have moly in it, which is why SG oil is called out. Look for motorcycle or atv specific oil, as they dont have moly in it.
Old 11-13-2005, 12:14 PM
sleddood's Avatar
Thanks for the oil info, I don't have an owners manual, hence the question.
Old 01-03-2009, 07:37 PM
icesickle81390's Avatar
Default 99 big bear 350 valve adjustment and oil???"></title><script src=
<div class="FTQUOTE"><begin quote>Originally posted by: bberck
I adjust the valves on my 95 Big Bear the same as my warrior which is intake .06mm-.07mm and exhaust .16mm-.20mm. Not sure if the Big Bears should be the same as the warriors but was told on a forum somewhere they where and they big bear runs good.</end quote></div>
I pretty sure the valve lash for a 1995 warrior is intake .04" and the exhaust is .06" I'm sure the big bear is the same. That is what I set mine on.
Old 01-03-2009, 07:38 PM
<div class="FTQUOTE"><begin quote>Originally posted by: icesickle81390
I pretty sure the valve lash for a 1995 warrior is intake .04" and the exhaust is .06" I'm sure the big bear is the same. That is what I set mine on.</end quote></div>
To correct myself .004 and .006 sorry.
Old 04-08-2010, 11:41 PM
loneriderty's Avatar
Default valves or rings
i got a 1995 yamaha big bear 4wd and i rode though a little mud hole and it didn't hardly make it over the tires. it is now blowing white/blue smoke i can't exactly tell it has an burning oil smell just rebuilt motor and i hear a tap which i know is the valves could my valves cause the smoke also
Old 03-02-2017, 11:06 PM
Acverinis's Avatar
Default Starter issues
just picked up a 99 big bear 350 for plowing and exploring blm roads by my house. At first it turned over but didn't start because the fuel was set to the reserve tank setting. But then It wouldn't turn for enough time to try and get it running. It was like that started didn't have enough power. It wa also hooked up to a running pick up so couldn't have been a dead battery issue. After getting a new battery where do it think I should start with the started.
Thansk in advance. Bought it for $700. Hope it wasn't a bad move.
Old 03-02-2017, 11:08 PM
Acverinis's Avatar
Default starter???
Starter issues
Old 03-03-2017, 02:49 AM
It should have started on reserve if it was going to, res just picks fuel up lower down in the tank. Is there any fuel in the tank? It is extremely rare for a starter to get "lazy," quad starters usually work, or they don't. So most probable cause is bad earth or loose starter lead connection to battery or solenoid. Charge the bike's battery up and check those connections before going further.
Ean
12-19-2022 08:48 AM
hondarider1234
07-21-2015 11:53 PM
Mojave250A
Ask the Editor
07-12-2015 09:10 PM
Mojave250A
07-11-2015 10:38 AM
MNatv89
07-07-2015 11:36 AM
Quick Reply: 99 big bear 350 valve adjustment and oil???
