blaster mods?
blaster mods?
port and polish. that would be good. get a 28mm carb and u will have a lot of power over stock imho. that would be about all i would do for trails and mud. then get some good tires, bars, and stuff like that. u dont need much more motor in the woods. mine does great on the track since i got it ported and shaved but i also does well in the woods and mud with my buds.
blaster mods?
Jets don't add power. If you are adding a pipe and air filter, you are going to have to mess with the jets. You can advance timing, by adding a Vito's degree key($20), or making stator adjustable Adjustable Stator. You can mill the head for increased compression($30). Add a aftermarket reed cage($150). Or aftermarket reed petals ($30). Reed Spacer ($30). The reed cages, reeds, reed spacer don't add alot of power, but add throttle response, which is good for the woods. Advancing timing and increasing compression add low end torque.
09-23-2015 06:23 AM
