warrior cams
Old 01-10-2008, 09:30 PM
viper23451's Avatar
Default warrior cams
i have an 2000 warrior and im trying to find out what cams would be best for my bike but i didnt want to have to change anything else i have looked at hot cams and they dont require any other mods but im not sure any help will be appriciated thanks
Old 01-10-2008, 10:06 PM
beefy46172's Avatar
Loves To Ride!
If you don't want to ***** with anything else than the Stage2 Hotcam is the way to go. However, I HIGHLY recommend you go to www.webcamshafts.com and get their racing grind cam, with the .430" lift. That cam requires new valve springs, but that also means it is really making a difference. It is much better than the HotCam, and you will be pleased. Of course, to take advantage of the added flow of a cam a good HMF slip-on pipe and a K&N Air filter would be great additions as well.
Old 01-11-2008, 12:19 AM
Raptor450's Avatar
What mods do you have now? If your engine is completely stock then a cam isn't going to do much, and too much cam on a stock engine will probably kill your bottom end power some. You need a pipe, filter, and jet kit 1st, then a cam. After you have those mods a Hotcam would be OK if you didn't want to do the valve springs, but to me, a Hotcam on a Warrior is a waste of time. If you look at the specs, a Hotcam doesn't provide much duration & lift over stock, that's why you don't need the valve springs. So what's the point of installing it? To me if a mod doesn't make a NOTICEABLE difference in power then it's a waste of time & money. Like Beef said, go with the Webcam, get the springs, turn in the cam core and you will be glad you did.
One other thing, if you look at the lobes on a Hotcam, they look similar to the stock lobes, but on the .430" Webcam the lobes are more egg-shaped and are huge compared to stock, and that's what you want if you are trying to make power.
Old 01-11-2008, 08:34 PM
viper23451's Avatar
thanks guys right now i have a supertrapp pipe with header, a k&n air filter with a modified air box, k&n jet kit and a procom engineering recitfier but ya i will probally get the webcam its not much more work than doing the cam ok thanks for the help guys i appriciate it
any ideas on what to do to beat a kfx400?? its my brothers and thats why im building this bike
Old 01-11-2008, 10:53 PM
Raptor450's Avatar
Is the 400 stock? If it is, a 10.5:1 compression piston, the Webcam with valve springs and some nice rear tires should do the trick.
Old 01-12-2008, 10:19 PM
viper23451's Avatar
ya the 400 is stock i got him on the take off and turns but its the straight aways that he pulls away. i got my bike dropped 2in and its 4in wider in the front and rear so it does handle great but i checked out your 97 warrior is that a warrior fame with raptor plastics from maier? cause i was looking at that plastics kit for my bike and i wasnt sure how it would look
Old 01-12-2008, 11:46 PM
Raptor450's Avatar
Nah, actually it's a '04 Raptor 350 frame and actual Raptor 350 plastics with all of my Warrior stuff bolted on. That kit from maier sucks. The Maier plastics look nothing like the real Raptor 350. I started out with Raptor 350 plastics on my Warrior frame, but it turned out all of the mounting tabs were completely different. I had welded new tabs on the Warrior frame to mount the Raptor fenders but it didn't turn out like I planned because I couldn't fabricate factory-looking tabs, so that's when I just bought a Raptor frame.
Scooter's Shop
23
10-22-2015 07:04 PM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
XxS0ccerstarxX
09-24-2015 05:38 PM
XxS0ccerstarxX
09-24-2015 02:02 PM
Quick Reply: warrior cams
