raptor660 problem!
raptor660 problem!
I had the same problem with my 2001 YFM660 Raptor. Faulty Ground -The fix was: Remove the main ground lug bolted to the engine Its located on the right side above the shifter foot rest use fine sand paper and clean the terminal and engine replace lug and bolt and tighten.
Good luck.
Good luck.
